Hi guys,
i'm working on my first attempt after years of looking into it for a few years.
i'm using a Thermaltake Xaser ||| case which i know it's old but i love it and has plenty of room.
Radiator: MagiCool 360 Copper Radiator III
CPU Block: Magicool CPU Cooling Block Revision II
CPU: AMD Phenom || 965
Graphic block: EK-VGA Supreme HF - Nickel Acetal (if they get some again)
Graphic card: Gigabyte radeon 4670
I'm not currently running any o.c. and not planning yet main reason to turn to WC is to cut the noises down specially while playing at night. Also noticed temperatures were way too high and with BF3 arrived i'm gonna be playing a lot.
Now first question is, will the loop descrived above be sufficient?
Also it seems the GPU block went out of stock while i was at the checkout so will need to wait for a new batch so should is start with only cpu and add the GPU block once it arrives or just wait?
Any advice appreciated
