First bike?
10 Jun 2010
Scotland
What is generally regarded as a good first bike? What's also recommended to a avoid?
I absolutely drool over the Kawasaki ninjas! However I'm a little apprehensive about getting one as my first bike, I dont want to end up in a wheelchair!
I'm learning on a cb500, they're supposed to betray according to reviews, but they're just so ugly! I really don't want to splash cash on a bike I hate the look of and don't particularly enjoy riding, just so I can get experience. However if it's a must, then so be it.
I love the look of super sports and sports etc. hate those cb500 naked bikes or whatever they're called. I quite like the look of late touring bikes like Harley's etc, but these cost a fair bit and not sure they'd be ideal as a first.
I'm 6ft 2 and my weight goes between 15-17 stone if that makes a difference to anything.
So words of wisdom wanted. Cheers guys!
Well, they only go as fast as you let them go. Depends how sensible you are.
How much do you have to spend? My first bike was a CBR600F for ~£3000 iirc, it was very light, flattered the rider and was cheap to insure. I'm 6ft and felt it was OK size wise, but really your probably going to want something bigger eventually due to your size and weight.
My cbr6F
Other bikes to consider, perhaps suzuki bandit and SV650 but really most manufacturers offer 600cc machines with either sporty or touringish characteristics. Depends what type of riding you might be doing, weekends, commuting, touring etc?
First bike for me - Suzuki GSXR600 K5
Had some good fun on it and it is still going well - fancy a change but can't afford it so as long as it is still running I will keep enjoying it
Just had the suspension set up properly about a month ago and that makes a heck of a difference too
Like the other guys I started on a cbr600fs1 2002:
I then moved onto a ER6F ABS (650cc) 2009:
I'm now in the process of selling the ER6F ABS if you're interested BTW.
I'm 6ft and 70kgs, both bikes had more than enough power for the newly passed and the ABS saved my neck more than once!
I do like the look of the naked bikes, just not as much as sports bikes...
My first 600 is a Yamaha Thundercat (YZF600R). It's been the ideal first bike for me.
As mentioned, it all depends on what you want your bike for.
My first bike was a Honda Hornet 600, great bike, easy to ride, dirt cheap to insure and very Modable. Re gear it and it will keep you entertained.
I did my first track day on my hornet, now ride a K7 GSXR 600 and love that too but miss the riding position of the hornet when on long runs.
my first bike was a K7 GSX-R600 and I loved it :)
I would say any bike 600cc or less is fine for a first bike tbh. Just be sensible to start with and you will be fine :)
Yeah I second the er6-f as it was my first bike, April 2011, and still own and love riding it to this day. Think it falls into the sport tourer bracket, as it is slightly more uprightsitting position than your sport bike class.
For info I am 6'2" and about 90kg.
how much you selling for :p
You are all lanky gits! :p:D
I can recommend the Kawasaki ER-6's (naked or faired) as I learnt on one and it was an absolute riot. A dam site quicker than I thought it would be!
You could look at the Suzuki GSX 600/650 as they are between the up right nakeds (like the Hornet) and the super sports. May not be as good as a Honda CBR600F though.
I am new to biking so don't blame me if I am wrong!:)
I am 6ft 3 and don't have any problems with my bike after a ride out, and as previously mentioned, as long as you are sensible most bikes will be okay but I would avoid the 1000cc supersport bikes to start with :p
Lol, I ain't selling it as it is all paid for - it is other reasons why I can't afford to change it just now and I can't justify the extra expense just to have a new(er) bike
i 3rd the er6 f :) was my first "real" bike after having 125's and me being 6"4 (83kg) my god is it comfortably and has more than enough power for me :) (well for now anyway ;) )
and it being a sports tourer the insurance is half the price of any sports bike :)
