First Bike
10 Jan 2012
UK
Guess what......
I passed my test! *does happy dance*
I've held of buying anything to avoid crying in the corner over my misery if something bad happened.
Anyway, I'm after suggestions for a first bike. I'm about 12 stone 5'11.
Will only be used to go to work and back (about a 30min car journey, which has very open roads on the way) and going out just to practice once in a while.
Don't need anything super powerful, but I will be going on the motorway, so will need something suitable that can go fast enough to do what bikes do best, overtaking (safely) and have nice gas mileage.
Don't want anything "sporty" just something sensible with a upright seating position.
Also would like some suggestions on gear (obviously full face helmet which I will go to a proper shop to get a proper snug fit), just curious on jackets, pants, gloves and boots.
I get hot easily so of put by leather jackets and gloves.
Also I'm aware you can get "biker jeans" which are just a tougher version of normal jeans instead of sweaty leather pants)
Also are the proper boots really needed? any alternatives as I can't carry comfortable shoes with me all the time (It sit at a desk for work so I would have to wear them all day).
I will be driving in the not so nice UK weather, so waterproof is a plus.
Any advice much appreciated.
Cost isn't exactly an issue, but nothing over the top and would like to keep it down if possible.
Honda varadero?
as for gear id pick
weise
spada
alpinestars
in that order for budget,textile clothes would be best,i used to change out of them when I got to work or wear some waterproof overtrousers?
boots you can go for the steel toe cap type ones either the shoes or the higher caterpillar type (you ideally want some that protect your ankle and are tall)
(ohh and congrats on passing:Danother one joins the club;))
My CBT instructor said much the same (with me turning up in a pair, in my ignorance).
You can, however, get a range of different ankle boots designed for motorcycling. Some of them look like regular casual boots, with some protective features inside. Some even look relatively smart. You can, of course, get ones that look like motorcycle boots to varying degrees as well, with features like reinforced toe sections for gear shifting (not a consideration for me at present). But plenty of them would not look out of place if worn all day. I don't doubt that you sacrifice some protection compared with "proper" boots though.
For example:
http://www.jsaccessories.co.uk/boots/ankle-boots.html
Guess what......
You will not only go to work and back - fact, once you have a bike and the freedom that it brings you will want to go everywhere and anywhere...it's not the same as a car, it's pleasure !
I wear gore-tex army boots and they're fine, I also sit at a desk all day.
Textiles are a good choice of protective clothing especially coming into winter - buy the best you can afford and try them on and read lots of reviews.
Welcome to freedom !
It's gonna take an extremely high impact to crush a steel toe cap tbh,I don't think the rest of u would survive long before it crushes the toe cap,
Not sure what the restrictions are now..
What power bike can you ride? Or aren't you restricted?
Not likely to crush yours toe in a bike accident tbf :p But definitely get proper motorcycle boots with full ankle protection!
Hornet? plenty of power for a motorway, and i find them comfy and easy to ride, considering the power its a very friendly bike.
Get a proper pair of boots and carry your work shoes in a bag, its what i do :)
on that note though when my r6 went down in the ice the steel toe cap stooped the peg crushing my foot where it got jammed underneath. it punched through a bit of the leather just behind the cap but the cap held solid, i think there would have been either a lot of tissue damage or broken bones without the cap.
I just got a set of john doe kamikaze cargo pants. 360 full Kevlar cover and water replant, it literally bounces off very warm an comfy can be a little sweaty if you're walking a lot though.
also videos of them dragging a guy behind a bike in them an no damage.
Had a look around
Thinking about this stuff
Jacket: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/117294
Pants: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/118236 (get these free with the first jacket jacket) or so I don't have to change my pants at work.
Gloves: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/37204
Boots: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/54392 (not sure on these)
Helmet: Won't be buying online, as have to try on in store for a real fit.
Or
Jacket: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/106659
Pants: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/190964
with......... http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/103770 to attach them.
Gloves: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/107875
Boots: same as above
Would that be good enough, wont be doing anything crazy just on road.
Still looking for a bike.
One thing I've noticed about both of the jackets is that neither of them say they have a back protector. One has a 'provision' and the other one says nothing.
They have the pockets for them, buy the inserts.
This is your life we're talking about here. All of the armour, especially the back protector, is absolutely necessary.
Well the ARMR doesnt have any hip protector inserts you can buy (useless http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/75755 can be used) where do they even go?
If it can be used, this is what I would be going for after looking around
JACKET: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/117294 with http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/140419
PANTS : http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/118236 with http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/75755
GLOVES: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/107893
BOOTS: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/54392
HELMET: Will buy from a proper shop for fit.
Or
JACKET: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/106659 with http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/75756
PANTS: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/190964 with http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/75755
With http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/103770 to connect them into one to keep backside warm
Also http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/33286 too keep in my back-pack if its raining as the pants are not waterproof
Same gloves and boots
