First boot - fans on, nothing on monitor
8 Feb 2012
Gigabyte ga-z77x-d3h
3570k
8gb corsair vengeance
Crucial m4
Corsair cx430m
Just powered on the pc for the first time and the fans are all running but nothing appears on the screen.
Checked 24pin and 4pin power connector with no luck.
Any help is much appreciated
Check memory locations as some boards are fussy in what slots are being used.
Also try a CMOS reset.
Just removed everything from case but still have problems. Looks like ill have to remove the CPU. How do I clean the thermal compound?
I have tried VGA and DVD but the monitor doesn't have an Hemingway so I can't check that. Monitor works as I took it straight from my other pc. Tried analogue and digital on the monitor itself
I have the ram in slots 1 and 2 (one on each channel) and I tried a CMOS reset but nothing happened
You installed ram in the second and fourth slot from CPU socket? So first slot empty second slot install third slot empty fourth slot install
