First Boot help Please. CPU fan running fast.
12 Mar 2004
Scotland
Hi all
Just put my system together and booted for the first time.
I have noticed that the PWM Akasa Viper fan that I fitted to the cpu cooler seems to be running at full speed (1900rpm) all the time in BIOS. This is with the BIOS temp reading around 28C.
Is this normal for the fan to be running so fast in BIOS and will it slow down to a more normal speed when I have installed Windows???
i7 930, Megahalems cooler, Rampage 3 Extreme, 6gb Corsair Dominator, GTX 285,
There'll be a setting in BIOS to enable control CPU fan by PWM. It's name may vary but should be easy to recognise.
Cheers Tealc. Found it.
CPU Q-Fan Control - Enabled
Then that opens up
CPU Fan Profile - Standard, Silent, Turbo
I think I'll leave it on standard for now.
