Hey,
I've been looking to build my own machine for a while and finally decided now is the time.
See below for what i am planning to put together:
CPU: Intel i5 4670k
Mobo: ASRock Z87 Extreme4 ATX LGA1150
GPU: GIGABYTE GV-N670OC-2GD GeForce GTX 670 2GB 256-bit GDDR5
RAM: Corsair Vengence 16GB (2x8GB)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case
PSU: SeaSonic S12II 620W 80 PLUS Bronze Certified ATX12V / EPS12V
Heatsink: Noctua NH-D14
HDD: Samsung 840 Series 250GB 2.5" Solid State Disk
My Budget in the region of £1000 but semi flexible. Will be used for primarily gaming but also some video editing.
I will also probably drop in a 1TB storage drive at some point also.
Any advice/ changes that you would suggest would be much appreciated.
Thanks, KingJonty
CPU: Intel i5 4670k
Thanks, KingJonty
