Hi, i've never built a pc before but i'd like to
. I'm pretty sure i know what i want from the pc but i'm not too sure about the components & would be really grateful if you'd let me have your opinions on this lot before i buy
Budget: £700-£800 (although i might be able to go a little higher if justified)
PC Uses: usual stuff such as internet browsing etc... ; gaming (usual resolution 1680x1050 on current monitor but the pc would also be hooked up to a 1920x1080 50" hd tv); watching hd movies @1920x1080; video encoding (using megui & handbrake) from 1920x1080, so i'm after a processor that will encode pretty quickly & efficiently.
Additional stuff: I'm also looking for a pc that, once i put it together, will run pretty quietly (so i'm looking for a quiet case, power supply & cooler) , be easy to maintain (keep free of dust) & also easy to upgrade with a few additional hard drives for storage purposes.
Anyway, i'd be really grateful if you'd let me know what you think of this lot & whether i could make better choices for what i'm looking for at the price i'm looking at:
PS i would be interested in going for 8gb of ram, rather than the 4 in the bundle, depending on price. Would make it easier to do other stuff while video encoding, which is processor intensive. Also, i'm ok for an operating system (win7 64 bit), hard drive (WD640 Caviar Black) & dvd drive, which is why i'm not ordering those.
Thanks in advance for any advice
