- 23 Apr 2007
Hi All,
After having had only Dells (I know....) I am planing my first own build and i was hoping for some expert advice from you guys.
Basically I use my computer for gaming and surfing.
I want to be able to upgrade cpu and graphics in the future but i have no plans on SLI or Crossfire.
I have already bought a Samsung 226 monitor and a Lian-Li PC-7 case.
I plan to buy after the July 22 price cuts and my budget is around a 1000£.
This is what i have so far;
Zalman Fan Mate 2
5.98
(£7.02)
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail £124.99
(£146.86)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) £87.99
(£103.39)
Arctic Silver 5 Thermal Compound (3.5g)
£5.99
(£7.04)
Noctua NH-U12F (Socket LGA775/754/939/940/AM2) Heatsink £32.99
(£38.76)
OEM Optiarc NEC AD7170S Serial ATA 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM
£16.99
(£19.96)
Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache - OEM £56.99
(£66.96)
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit (BL2KIT12864AA804) £74.99
(£88.11)
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard £81.99
(£96.34)
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM £279.99
(£328.99)
Subtotal £768.89
£903.45 inc VAT
My biggest doubts are regarding the CPU and motherboard. Should I go for a Q6600 and/or an Abit IP35-Pro instead??
Any help is much appreciated!
Zalman Fan Mate 2
5.98
(£7.02)
(£146.86)
(£103.39)
£5.99
(£7.04)
(£38.76)
£16.99
(£19.96)
(£66.96)
(£88.11)
(£96.34)
(£328.99)
Subtotal £768.89
£903.45 inc VAT
