First build advice needed
15 Jul 2012
hello all (And thanks to all those that have helped me already)
Ok so all my new parts for my new build are coming but here is where I need some final help, the old parts I will be using are:
Wifi Card, 1 tb Hdd, Oc'z 650w psu, Cd/dvd drive and gtx 560 ti gpu.
So should I be thinking of replacing any of these parts before I begin my new build, I will also be using Windows 8 instead of the current windows 7 I am using.
Any help would be great
There is no need to replace the old components, unless you want to upgrade the 560ti. Is it the 1GB or 2GB version?
HDD + optical - if its SATA keep it
Wifi card - If its PCie keep it (may want to upgrade to N band if its not but only if your router supports it)
GPU - Keep it unless the games your playing need more grunt, the longer you wait the bigger difference your money will make side by side.
PSU - as long as its working keep it, you may have to buy some adapters for your new hardware but there only a couple of quid.
Good luck with Win 8 I lasted less than a day before rolling back to win7 but then i still run XP on my lappy as i'm a ludite.
