First build - advice on components
15 Aug 2009
I have been going round these forums since deciding to be build a new PC myself for the first time, and the information here is really great.
The PC will be mainly used for gaming for my two boys who love racing games (I like to do a bit of gaming myself too) and for general internet/word/access/exel use. It will also serve as a DVD player for the boys. I might think about overclocking in the future, but not right now. I have been mainly using laptops right now, but they seem to die on me at a rate of one a year (for some reason right after the warranty ends every time) so I thought getting a decent desktop which I can upgrade bit by bit is more sensible.
I have already placed the order, but it seems there have been some delays so i think they will be shipping next week and I have some time to change items if you think they are not suitable. I will be getting the following parts:
LG Flatron W2261V 22" Widescreen LCD Monitor
AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3) - Retail
HIS ATI Radeon HD 4890 1024MB GDDR5 PCI-Express Graphics Card - OEM
Antec 902 Nine Hundred Two Ultimate Gaming Case - Black (No PSU)
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK) + 3D Mark Vantage Benchmarking Software
Asus M4A77TD Pro AMD 770 (Socket AM3) PCI-Express DDR3 Motherboard
Seagate Barracuda LP 1TB SATA-II 32MB Cache - OEM (ST31000520AS)
OCZ Alchemy Series Elixir 2 Keyboard (OALKBELX2UK)
I have a few other parts from an older PC I got from my dad (like DVD player etc)
appreciate any advice!
HD 4890 System ... 500 Watt or greater power supply with two 75W 6-pin
Cheapest id get is this at least..Out of Stock :(
OCZ StealthXStream 600w Silent SLI Ready Power Supply
£54.99 inc VAT
http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-OC&groupid=701&catid=123&subcat=
edit, great deal, This Week Only Offer
OCZ ModXStream Pro 700w Silent SLI Ready Modular Power Supply
was £75.99 inc VAT
£62.99 inc VAT
http://www.overclockers.co.uk/showproduct.php?prodid=CA-032-OC&groupid=701&catid=123&subcat=
I have a 400W power supply from the older PC - do you think it might be stretched out?
g
Get a new one. That could be a bad move re-using that.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-CS&groupid=701&catid=123&subcat=1084
That would be my choice depending on your budget. the Wattage isnt so much an issue (although 400 might be pushing it) but if it is an older model or unbranded then it won't cutthe msutard and could fail/cause instability/fail and take other components out with it. Plus if you (as you say) plan to clock in the future, a PSU that can supply more amps on the rails would help
- Pea0n
reygjabla - I actually ordered that GPU initially - it was on special offer last week, but they told me it was out of stock when I placed the order. I will try getting it again!
edit - actually it was a different model, sorry
was going to mention the one on special offer - will try that
thanks!
£54.99 inc VAT
was £75.99 inc VAT
£62.99 inc VAT
By the way, are you planning to put your OS to the Seagate 1T? To me, that seems quite risky! If the HDD crashes you'd lost all your files and might take time and resources to recover if ever it's possible. I would suggest one HDD for OS, application and games and, another HDD for your Data.
Yes I agree - I already have a couple of other hard-drives for data
