Hey guys, I need some advice on my first ever build.
I am looking at a budget gaming pc and think I have everything I need and/or want. But I don't want to go and spend 300 quid on parts and then end up cocking them up. So please tell me if this is the right way to go
I want to be able to run and play cod4:mw2 and I am hoping to upgrade as times go on.
How easy will this be to build and will it work?
Shiny Black Midi Case 450W
Gigabyte ATI Radeon 4670 HD 1GB DDR3 PCI-Express 2.0 DVI
Asus S775 Intel G41 mATX DDR2 Audio & Gigabit Ethernet
Intel E6300 2M Cache 2.80 GHz 1066 MHz FSB LGA77
Corsair Memory 2GB DDR2 XMS2-6400 240 Pin
Maxtor 250GB 3.5" SATA 7200RPM 8MB
Akasa 80x25mm Fan Black
16" Eclipse15 Widescreen 8MS LCD Monitor
I want to be able to run and play cod4:mw2 and I am hoping to upgrade as times go on.How easy will this be to build and will it work?
