Hi,
I am looking to build a new pc and would like to post the specs ect see if you can offer any advice. I actually work as IT assistant and have built rigs in the past, the reason i've come for advice is because it's my own High end-ish rig. I currently run a core two duo at 2.66GHz but i don't feel it's good enough any more. I mostly browse, play low end games like TF2, Gary's mod, Minecraft ect...
If you could offer any advice to the rig build it would be much appreciated.
The specs i'm looking to buy are
1. Processor - AMD Phenom II X4 3.4 GHz Processor
2. Motherboard - ASUS M5A87
3. Memory (RAM) - Corsair XMS3 4GB DDR3 PC3-12800C9 1600MHz
4. Hard drive - 500GB one from previous computer running windows 7
5. Graphics card - XFX ATI Radeon HD 5830 1024MB GDDR5 PCI-Express
6. Power supply - Corsair Power Supply ATX 650W TX V2 Series
7. Case - Need advice for this?
8. CPU cooler - Need advice for this?
9. Case fans - Need advice for this?
10. CD/DVDRW drive - two from previous computer
11. Optional: Already have Sound card, PCI wifi card.
The reason I ask is specifically about the case i don't want to spend more than £60. Also if I'm running stock speeds should I invest in after market cooling? Although i might take a look into low overclocking. Aswell is it worth me investing money into a small SSD for my operating system?
Thanks
Xavier
Thanks
Xavier
