I am currently putting together my first build and have a question regarding fan configuration.
I have an antec P183 case which has come supplied with 2 fans installed, one on the rear, one on the top (both currently set to expel).
I have got a Corsair H50 cooler which I also need to connect to a fan.
My current thought is to reverse the top fan (H50 instructions say to have the radiator fan as an intake) and connect to the radiator. Then use the fan supplied with the cooler (it appears to be identical to the Antec fans) and set this as an intake on one of the front fan mounts.
Is this the best way to set this up and which of the front fan mounts would I be best to use?
Thanks for the help
Thanks for the help
