Hi,
Could someone confirm if I have everything set-up correctly before first boot? Have I missed anything?
http://dl.dropbox.com/u/5602408/Cabling.png
If a picture is wider than 1024 pixels please provide a link instead. Thank you.
Questions (in White):
Many thanks!
- Case: Corsair 'Carbide 500R'
- Mobo: Gigabyte 'GA-Z77X-D3H'
- As i've used both SATA 3 ports up for the SSD and HDD, which is best for the CD Drive? SATA2 or SATAG?
- Should I be plugging the IEEE 1394 front panel Firewire connector into the mobo somewehere?
- Is my assumption about that case Molex connecter being the power for the front-side adjustable fans correct? Does it sound as though I've set it up correctly?
Many thanks!
