14 Jul 2008 at 11:14 #1 Rangler Rangler Associate Joined 8 Mar 2004 Posts 888 Location Leicestershire Hi all, Gonna be building my first HTPC very soon and need your expert opinion on the following parts please. I have a 7600GT which will go in as a stopgap solution. Thoughts please people
14 Jul 2008 at 12:07 #2 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK I'm not totally sure that cooler will fit - isn't that a low profile case?
14 Jul 2008 at 12:12 #3 Teaf Teaf Soldato Joined 17 Dec 2006 Posts 8,232 Yeah almost certain that the cooler won't fit - a Scythe Ninja Mini would be a better choice if you wanted an aftermarket cooler.
14 Jul 2008 at 12:48 #4 Rangler Rangler Associate OP Joined 8 Mar 2004 Posts 888 Location Leicestershire Cheers i'll look up the mini now.
14 Jul 2008 at 13:13 #5 Rangler Rangler Associate OP Joined 8 Mar 2004 Posts 888 Location Leicestershire Hmm youve got me thinking now, will a normal height gfx card fit inside this ok.?
14 Jul 2008 at 14:28 #6 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK Well if it's only an HTPC then it doesn't matter. You can use the onboard, or there are plenty of low-profile cards that are good for the purpose.
