So my ageing laptop is slowly dying and i thought i might as well splash out on a new computer now than wait for it to fully die.
This will be my first ever build, so any advise on the components would be great
The budget at its max is around £500 for tower + keyboard, i might need an OS but not sure yet, ive specced without one for now. Anyway heres the spec i came up with.
Sapphire ATI Radeon HD 5850 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** £116.99
Asus M5A97 EVO AMD 990X (Socket AM3+) DDR3 PCI-Express ATX Motherboard £94.99
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £89.99
Cooler Master Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £64.99
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) £39.98
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £34.99
Logitech K300 Compact Keyboard (920-001488) £14.99
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £14.99
Comes to around £471
First question is, my monitor i have is 20" and only connects via vga, does the 5850 come with a dvi to vga converter?
Second question is will cooling in the case be sufficient? or should i throw in a 120mm exhaust fan for the rear of the case?
Any advise would be greatly appreciated and if i have missed anything out let me know
Thanks
. The budget at its max is around £500 for tower + keyboard, i might need an OS but not sure yet, ive specced without one for now. Anyway heres the spec i came up with.
Thanks
