First Build: DONE! :D
16 Nov 2010
Swimming in a lake
Ok, so it's finally done :) After months of planning parts, then buying them for another couple of months, then waiting for them until I get them all home to build them, today I finally got to build my first ever PC :D
Hopefully, this is the beginning of a long and happy friendship :)
There were a couple of hitches along the way, however I'm guessing everyone wants pictures!
So here's a little walk-through my day today!
I must admit there aren't as many pictures as I'd like, because I got a bit carried away with building!
So here goes!
The Parts:
The Case: Lancool K62
This is having both side panels off, as I was about to change all the fans in the case! Without a doubt this is probably the part that required the most screwdriver use! Over the whole experience of the build, only the fans really required a screwdriver!
Top and Bottom off, revealing old fans!
New Fans to go in!
An Enermax T.B. Silence 120mm for the rear, and 3 Xigmatek CLF's with purple LED's (140mm). I must say, I tested these out before I put them in the case, and the Enermax really is silent. It's rated at 11db, and having only it plugged in, I could hear my PSU over it! The Xigmatek's are slightly nosier, at 16db, however are really quiet for LED fans. Saying that I'm slightly disappointed with the LED's having put them in. They're not very bright, but we'll see this in later pictures!
New Fans In!
Not much to say here, they went in fairly easy, so long as you knew how to use a screwdriver and weren't stupid enough to put the front fan in back to front and then realise your mistake *cough*.... Removing the HDD cage to get the front fan in was a requirement, but this was simply only 3 screws, and really wasn't much of an issue.
Motherboard out, and CPU in.
Asus P8P67 and an i5 2500k. This was fairly simple, and in all honesty, I must say I do like the little things done with the Asus motherboard. Simple things like the ASUS section being highly metallic and stuff, you can just feel the quality really....
Heatsink on
Corsair A70, got a good price on this on the MM. It was surprisingly heavy, creating some bend in the motherboard, before I mounted it in the case. However it was dead easy to install! Just with thumb screws :) Oh and RAM went on before I mounted the Heatsink. 4GB of XMS3.
Into the Case
Motherboard goes into the case and the standard Corsair fans go onto the heatsink, Got it in Push Pull Expelling out the back. This was again a nice simple operation with the K62. They even give you thumbscrews to install the motherboard!
PSU in.
In goes the Corsair HX650W. Again this was a dream to install. The case has a fantastic clip system, so you simply have to put the bracket on, pull it down, and the PSU is in rock solid. I should say I did screw it in as well however, as they recommend it for if you're moving the case, but to be honest I don't think you need to.
Hard Drives, Optical Drive, and Graphics Card go in.
A Corsair P3 64GB, an F3 1TB and an ASUS GTX480. Originally I mounted the SSD in the bracket it comes with and then into the case, however I discovered that this way the SATA power cable hadn't to be bent a bit too much, so in the end I decided to mount it into the screw holes on the HDD Cage (This is why it's moved in later pictures. The F3 was literally just stick it in, toolless again! The optical drive is the one in the picture at the beginning, the £14 Samsung one, however once everything was up and running, I ended up switching it out for the one in an old computer as that has Blu-Ray (pictures later). Finally the GPU. The 480 is a beast :D I must say, having had it next to me, the noise isn't really as bad as people say. It took up two pci brackets on the back of the case, however again, this is toolless due to the fantastic design. It was really simple getting it in to be honest. It does hang slightly, due to the weight, which caused minor issues plugging in the DVI cable, however that wasn't a real issue!
Some wiring up:
Just some minor things here really, as you can see I've plugged in the power for the Harddrives, and the SSD has been moved as mentioned earlier.
IT LIVES!
This is just a photo of installing Windows (something we ended up doing 3 times as I kept trying to sort out the Secondary drive and folder locations and killing the install) In the end I gave up trying to junction it and just redirected the folders.
The monitor by the way is an HP 2310ti, 23 inches of touchscreen heavenliness!
Soundcard.
Well everything went in, and it came upstairs into my bedroom so that it could plug into the internet! (Hence the change of background). Once I'd installed all the drivers etc.. for Graphics/Motherboard the sound card went in! As seen here. Absolutely fantastic soundcard though, it has some nice small things that make the difference (e.g. lights in all the audio out connectors at the back colour coded to the cable so you can easily change them, or see them at night) I should point out that the fans are purple, my camera just doesn't seem to like the colour.
Couple of Close ups of the Heatsink
DVD Drive switched. Switched the DVD drive out from the case with the one from my old pc which has blu-ray :D
So the cable management begins!
After all of this, I couldn't actually get the side back on the case (non-windowed side) because of all the cables out the back. However, considering this is a first build, I think it ended up ok on both sides, with a reasonable compromise! Here's a couple of pictures to show the end result (a good hour of extra cable management after building) I should mention as well getting the 8 pin motherboard power cable through the top of the case and out the hole, was a complete PIG! Took a good 10 minutes of swearing to get that through!
A couple more finishing shots!
The compulsory night time shot:
Again the lights are purple, just camera's a bit :S To be honest, I'm still a bit disappointed in the brightness of the LED's...
Conclusions:
Overall, I'm pretty damn happy with the whole thing!
The case, despite a couple of niggles was a complete dream to build in, and all in all great fun :)
It really is quite easy doing your first build, software was probably the biggest issue for me, and even that wasn't too bad!
Oh, and the touchscreen is SO awesome
As a testimony to the success, it was in pieces this morning, and now I'm posting this whole topic whilst on the pc it's about!
Another thing that I do like, is SSD's! No longer do I have to go, 'oh I'm turning the computer on, let's go make a drink...' (On my old computer I had time to shower before it had finished booting up...) Now I think the slowest part of loading the computer, is me typing in my password....
As for what's going to happen next, I'll update this as and when I get some Benchmarks up, what do people recommend? Reckon I should do?
I doubt I'll overclock it for now, as I don't really have the need for it, if I feel it's getting slower, I'll do so for that extra bit of oomph, but right now, it's not needed so I doubt I'm going to.
For now however here's a pic of idle temps:
Frankly I'm a bit unsure about the temperature difference across the cores! So might have to reseat the heatsink at some point :S
kd
just read your post and loved it. the computer looks really nice and as above should perform really well from my novice experience lol. i've just bought a value system and seeing posts like these make me want to spend lots of money. :)
Maybe the A70 on there without you overclocking was a bit overkill xD But it does give you headroom for the future as you said :) Great for a first build though mate, wish mine went as smoothly :rolleyes:
aaahhhh....was wondering if you would use the a70 in your build,glad you like it and the temps look good,might be worth leaving the a70 on for a while to see how the temps settle down.
well done for your 1st build dude.
Nice first build, good job.
All you need to do now, KD, is to switch those Purple LEDs for some decent colour....something like, umm I don't know.....Orange perhaps?
I bought some Purple LEDs a while back (100 of the buggers) and was somewhat underwhelmed by the light output.
Yeah, I've been somewhat underwhelmed by them myself to be honest... I could go with Orange, it would match the Soundcard xD But no I'm actually looking into a darker green, as you've seen :) But might go grab a couple to test with to see what the light output is like considering how disappointing the purple has been on these....
Switch your hdd's around so you dont see the cables. thats my only gripe, get clocking matey
Yeah I might do this somehow, the power cable does bug me, so I might move the HDD down to the bottom so the power cable has to stretch and shouldn't be as obvious... Definitely need to work that one out as it's what's bugging me the most atm as well!
The A70 might be a slight overkill admitedly for the non-overclocked CPU, but I did get it for a good price, so it sits there nicely and as said gives me the headroom when I will in the future. I might even just stick it at 4GHz after it's settled down and see how things go...
Going to be a completely different experience running everything on max rather than low now though! :D
EDIT:
Well Here's a Heaven Run :)
Everything on standard, this seems a pretty normal score to be honest :)
kd
that is really similar to my recent build, except i have a cm 690 ii case.
I agree about the Asus GTX 480, not too loud and I have clocked mine to 810mhz on stock volts ant temps are really good!
Thats a really nice first build there KD, you have done a great job. Also a good build log too with nice pictures. Well done.
Really well done. Great choice on the fans as well, those are really popular but for a good reason.
Like the case as well, it would look really appealing with some neon lights though i understand thats not to everyones tastes :) also the CPU temps they were really nice as well. I haven't been able to try out any I5's other than the i5 2320 that i didn't real appeal to me but the 2500K is a lot, lot better, evidently. If you haven't overclocked it i suggest getting it to 4.4GHz, with that cooler it will run cool and you will see a great performance boost in CPU heavy application as of course that goes without saying :P
How did you manage to bump this thread? XD
