Hi guys, I've tested the build outside the case first (RAM, graphics card, CPU, power supply) and all good with the splash screen and no operating system message.
So, onto the case now, I'm using this motherboard and case.....
Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
Corsair Carbide 300R Mid Tower Case - Black
Just checking and triple checking these stand off things, they look like kind of raised bumps with the middle one having a bit of metal sticking up from it, placing the motherboard on it matches exactly with the holes.
Do I need to put anything else on these bumps or do I just place the board on and screw it in place?
Thanks
Thanks
