Hi everyone, Im new to the Forum as well as to building my first Computer. I would appreciate you looking over my parts I will be ordering, if it passes your scrutiny, obviously im looking for guidance to ensure the parts will work well together.
1.http://www.overclockers.co.uk/showproduct.php?prodid=CA-154-LL
Lian Li PC-V351B Aluminium Micro ATX Cube Case - Black £89.99
2.http://www.overclockers.co.uk/showproduct.php?prodid=CP-418-IN
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) – OEM £184.99
3.http://www.overclockers.co.uk/showproduct.php?prodid=MB-394-GI
Gigabyte Z77MX-D3H Intel Z77 (Socket 1155) DDR3 Micro ATX Motherboard £99.98
4.http://www.overclockers.co.uk/showproduct.php?prodid=GX-289-AS
Asus HD 7850 DirectCU II V2 2048MB GDDR5 PCI-Express Graphics Card £179.99
5.http://www.overclockers.co.uk/showproduct.php?prodid=HD-336-WD
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) HDD £79.99
6.http://www.overclockers.co.uk/showproduct.php?prodid=CA-229-SV
Silverstone Strider Plus 500W Modular '80 Plus Bronze' Power Supply (SST-ST50F-P) £67.99
7.http://www.overclockers.co.uk/showproduct.php?prodid=CD-115-LG
LG CH10LS28 BD-ROM 10x BluRay ROM / DVDRW SATA-II Optical Drive £59.99
8.http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-CM
Cooler Master Hyper 212 Evo CPU Cooler £26.99
9. I already have a Scandisk 128GB SSD which will have Windows 7 Home premium on it.
Still require memory! can you suggest some please, probably just 8Gb or maybe 16Gb if that would be better
Again this is my choices above, feel free to swop,suggest changes as you please. The computer will be sat on my desk in a bedroom so thats the reason for the size of case etc. it will be used mostly for games (crysis,Halo etc) and family photos.
Cost wise! well id like it to keep it under the £800 mark if possible.but i can stretch that if required.
Many thanks in anticipation
