First off iv bought a grade b motherboard, it came with no screws? (do these norm come) no cables (what do i need to buy 3x sata do?) and no standoffs (do i need some for this board)
Also it came with no driver disk or anything like that.
the screws and standoff's are not supplied with motherboards and are provided with the case. I would not be concerned about the driver disk tbh, go to the website and get the latest set of drivers and manual which should be more up to date as well. As for the cables, that depends on you particular setup, do you have any already? Check your hardware and work out how many you need for sata/fdd/ide etc.
That is what you generally get with a b-grade board though.
