First Build Help
6 Feb 2011
Hello,
I am planning my first build, I have picked out a spec below. How does this look? The specific worries I have are, is the power supply powerful enough, is the kit all well balanced, and will SLI work properly with the mainboard (I want to run three screens) ?
Thanks,
Chris
Intel Core i5-2500 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics (*2 for SLI)
MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION **
Corsair HX 750W ATX Modular SLI Compliant Power Supply
Coolermaster Storm Scout Gaming Case - Black
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM
Yep looks good mate, but get the K variant of the CPU, this allows OCing, even if you dont want to do now, you may in future, plus it should have higher resale value too
Edit: Though the HDD wouldnt be my first choice, SATA 6Gb/s offers nothing to mechanical drives so youre paying for a gimmick, just get a Seagate 7200.12 or Samsung F3
Ok, so revising my initial proposal:
Removing i5 2500 for a,
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM
and adding a,
BeQuiet Dark Rock Advanced CPU Cooler
Looking at the ASUS P8P67 PRO, am I correct in saying it has support for the four usb 2.0 sockets on the Coolermaster Case, and the MSI board can only support two, but whereas the MSI board has 2x PCIe 16x the ASUS board can only run the two PCIe slots in 8x when using both?
Chris
i think that i have read somewhere that the MSI board when it is running SLI also goes from x16 to x8 speeds (someone might be able to confirm/prove wrong) its just not stated on the OCUK site.
ASUS boards are also well known for having high quality and have lots of good reviews.
and yes i think thats correct about the USB 2.0 ports
According to this review you are correct, http://www.pcstats.com/articleview.cfm?articleID=2579 , the MSI board does drop to 16x/8x when in SLI. For my purposes this is better than the asus as according to this article, you can get a drop in performance using 8x/8x when using three screens, http://www.hardocp.com/article/2010/08/23/gtx_480_sli_pcie_bandwidth_perf_x16x16_vs_x8x8/ .
Is there anyway around the front usb port issue? I dont mind modding the case so if its not terribly difficult could I replace one external usb 2.0 port pair to a usb 3.0 port pair, as the motherboard does have a usb 3.0 internal connector?
awesome, then im sure if you are willing to do a bit of case modding (and you can get hold of some USB 3.0 case ports. then you could do it.
