You can try it like it is. Probably be okay, just not the best airflow.
If it was me I would turn cooler or duct it out a top vent (I opened both top vents and ducted cooler out top).
Add another fan in bottom (increased air pressure/flow into case means more going out.
Remove unused PCI slot cov).rs (for airflow out back).
Move GPU down to next slot (so air will flow out both above and below GPU).
I might have a fan you for bottom intake if you need one but don't have an extra grill for it. I use the round wire target like grill to protect fan blades.
