Hi, first post here.
My laptop has failed on me after 6 years of use, so I decided now is a good time to try my hand at building a PC myself as a replacement.
I don't want another laptop as I find the cost to power ratio way too low, so I thought an m-itx build is probably the closest I can get to a laptops portability. (only moving around the house with it).
So for this post I was just wondering if anyone had any recommendations for components that have a good bang to buck ratio, to start I'm looking at cases.
Budget: 400 (flexible)
Use: I have a main desktop, but I'd obviously like it speedy, and be able to handle current gen games to some degree. Maybe a bit of a console killer?
Would ideally like a case that supports large video cards, for convenience.
Looking at:
-Bitfenix prodigy
-Thermaltake core v1
-Cougar qbx
-Corsair 380t (bit expensive)
Does anyone have any experience with these cases, or any recommendations for a build? Open to suggestions.
Cheers
Looking at:
-Bitfenix prodigy
-Cougar qbx
Cheers
