Hi, I am putting together some parts for my first gaming PC. Never built or owned one before but always wanted to!
I have looked around and read up about a lot of parts and have so far came up with the following:
PROCESSOR - Intel I5 3.3GHZ Quad Unlocked = £170
MOBO - ASRock Z68 Extreme4 Gen3 - £150
GPU - MSI GTX 560 Ti - £180
RAM - G-Skill 8GB (2x4GB) DDR3 1333MHz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V - £38
PSU - Corsair Enthusiast Series TX650 V2 Power supply - 650 Watt - £65
COOLING - Coolermaster Hyper 212 plus - £25
CASE - CM HAF 912 plus - £65
DVD Drive - SATA 22x DVD Writer SAMSUNG SH-S222AB/BEBE - £15
HDD - WD 1TB 3.5" SATA-III 6Gb/s Caviar Blue Hard Drive - £100
OS - Windows 7 64 bit - £70
Total - £878
Is this going to be a decent build? Would like to be able to play most things on high settings, not worried if they aren't maxed though! Will play wow, diablo 3, battlefield 3 etc.
Will a 650W power supply be enough? Will probably overclock but have not looked too far into it yet.
Wondering whether I would need to get some extra fans for the case too?
Also I am going to need a decent monitor, 22"-24" and full HD if anyone has advice on that? Want to spend about £150 on it.
Any advice will be much appreciated!
Thanks in advance.
Total - £878
Thanks in advance.
