Im building a desktop to replace my old laptop and because it seems cheaper than a pre-built system.
I have researched and come up with a list of parts. The main use of the system is using Visual Studio and Adobe CS5. I also watch a lot of movies online.
What I have currently:
Monitor: Samsung S24A350H 24 inch (HDMI/VGA)
External HD: 2TB LaCie P9230 (USB2 & USB3)
What I think I need (from my research):
Processor: Intel Core i3 2120
RAM: minimum 4GB, made by "Crucial"
Graphic Card: For my use, not sure I need this.
Hard Drive: 500GB as I can use my external HD.
Power supply: Not sure, 400W to be safe?
Motherboard: Not sure, one that works with what I have!
I will need a case, optical drive and possibly a fan. Also, the system needs to be compatable wiht my monitor (HDMI or VGA).
My budget isnt great, but im not expecting wonders from this system. I would prefer to spend £200/ £250. Hopefully, that is do-able.
Thanks in advance guys
Nathan.
Nathan.
