- 17 Jun 2012
Hi all,
So I'm in the need of a Gaming PC, I've spent the last couple of days browsing the net to find out what I should go for, but I just have no clue where to start.
Build or buy a pre built system? That's my first question...
Then I looked around and read through forums etc... And looks like build is a little cheaper but not much?
Okay so I want a machine that will run BF3 on at least high settings, as console doesn't quiet cut it anymore.
Anyway my budget is £700 preferably less. I need windows 7 as I'm still running XP. I have all input devices and sound system, not sure if it makes a difference but my resolution is 1050x1680.
Any help would be ace! Just can't figure out where to start.
Regards Tom
Regards Tom
