First Build no image on display HELP!
2 Jan 2010
Hey there, just finished my first build, built it on a budget,
basically compromises of
Amd Sempron 140
stock cooler/fan
GA-m720-us3 Mobo with no onboard graphics
7950gt GPU
4gb ddr2
650w Psu
so ive propped it all together today and went to go and try it on my 32inch Tv but has the capability to display my dell 1545 so i think it would be able to display with the gpu,
ive got a splitter from a dvi to a vga all attached ive installed the gpu on the pci express slot, and ive not attached anything else to the gpu the fan is spinning,
dont know what else to do!
Thanks btw the Tv works perfectly so im either thinking its the gpu or something on my mobo
Cheers in advance Garry
if there is a pci express power input on the card plug the cable into it! :)
also i would test this machine on a monitor before trying it out on a telly. resolution issues and all that.
