First Build - Only boots via onboard power
1 Jan 2009
I've just put together an i7 rig and the problem seems to be that the machine will only boot if I use the on-board power button. If I use the case (
Coolermaster Cosmos 1000) power button it turns on for 5 seconds then turns off. I've gotten into the bios and checked everything which appears normal.
Any ideas? I've checked the connections on the case > board (Asus Q-Connector) and it seems correct.
The specs are:
Core i7 920
Asus P6T Deluxe
XFX GTX 280
6GB Corsair DDR3
Hope someone can help!
