Hi folks,
Im looking to run a quick spec check past you to see if im picking the right parts. This is not going to be bought for a month yet though (still short £200 till next pay
)! I also have some questions (see below).
Ok so the spec right now is:-
Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Black £49.99
(£58.74)
OCZ ModStream 520w ATX2.2 Power Supply £54.99
(£64.61)
Intel Core 2 DUO E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail £95.99
(£112.79)
Asus P5B (Socket 775) PCI-Express DDR2 Motherboard £69.99
(£82.24)
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £99.99
(£117.49)
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £164.99
(£193.86)
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM £56.99
(£66.96)
Seagate Barracuda 7200.9 80GB ST380811AS SATA-II 8MB Cache - OEM £27.99
(£32.89)
NEC AD7170S Serial ATA 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM £18.99
(£22.31)
Scythe Infinity Heatpipe CPU Cooler (Socket 478, 775, AM2, 754, 939, 940) £26.99
(£31.71)
Microsoft Windows Vista Home Premium 32-Bit Edition DVD - OEM - 1Pk (66I-00715) £61.99
(£72.84)
Sub Total : £728.89
Shipping : £10.95
Vat : £129.47
Total : £869.31
How does this look? Would you make any changes? My budget is around £850 - 900.
About the OEM Hard Drives and Optical Drive... do they include the SATA Cables etc. or just the drive it's self? aka will I need to buy cables? If so I dont have a clue what I need
Also about Vista - I understand I can run 64-bit but have been reading about problems with it? so 32 or 64 bit?
Thanks a lot for your help!
Dave
)! I also have some questions (see below). Ok so the spec right now is:-
(£58.74)
(£64.61)
(£112.79)
(£82.24)
(£117.49)
(£193.86)
(£66.96)
(£32.89)
(£22.31)
(£31.71)
(£72.84)
Sub Total : £728.89
Shipping : £10.95
Vat : £129.47
Total : £869.31
Dave
and yes 80Gb - Windows 320Gb - Games etc.
