Hey, im new here, just got my account validated
I am hoping to build my first new computer.
Looking forward to it loads.
Need it to be pretty cheap, as i don't have the biggest budget.
Not really in to gaming, maybe a bit of The Sims 2 here and there
Mainly going to be used to stream movies from the pc to my tv, and general browsing, downloading, msn, and encoding movies etc.
Just a quick spec check before i order bits and bobs;
Intel Core 2 DUO E6400
Gigabyte GA965P-DS3 (Socket 775) PCI-Express DDR2 Motherboard
GeForce 7600GS 256MB DDR2 SLI, DVI, VGA, PCI-E
Akasa AK-ZEN-01-BK Zen Black Case
OCZ Modstream OCZ52012U 520W
Maxtor DiamondMax Plus21 160Gb 2Mb Cache SATA II Hard Disk Drive <11.0ms 7200rpm - OEM
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
Will be using optical drives from this current (old) pc im on atm.
I guess i won't be able to use my 250GB IDE hdd with the DS3, so that's got to go, might add another hdd later on.
Comes to £556.54 all in all.
So its not that bad, any recommendations? Do's and Dont's will be greatly appreciated.
Jay
Jay
