First Build
20 Feb 2007
I am about to order parts for my first build and i am currently looking for a case and psu i have gone for a cheap graphics card for a few weeks until i can buy a 640mb gts any input would be appreciated.
OcUK GeForce 7300 GT SILENT 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £21.99
(£25.84)
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM £43.99
(£51.69)
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard
(£88.11)
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail £127.99
(£150.39)
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663) £69.99
(£82.24)
Welcome to the forums, that looks like a good system. As Shine says a Corsair HX 520w PSU is a nice choice, case wise the Akasa Zen is decent for ~£30 or the Lian-Li PC7+ for ~£50. :)
they look like good psu's but i dont have a clue about psu's so i am just going by what i have read on the forums
on the cases i am not worried about the price as i will most probably buy a cheapish case for the moment until i have the money to buy a case i find is a good one for cooling as i will be overclocking in the future
I recommend the Corsair range of PSUs, HX520W or HX620W
Also, i recommend the Lian-Li PC-7+, its a great case.
If you are looking to overclock, i would invest in a good heatsink.
phil2oo7 said:
for the heatsink i was thinking about the tuniq tower
Sounds good, if you are after quiteness, look around for a Scythe Ninja Rev. B, as they have an optional fan, which is included in the box, but you don't have to put it on, so the heatsink is silent.
