I need a new pc for normal browsing some gaming (Minecraft). This is the spec I have been looking at;
Phenom II X4 955
Asus M5A78L-M/USB3
Corsair Builder Series CX 430W V2
BitFenix Merc Alpha Gaming Case
Crucial Ballistix Sport 4GB (2x2GB) 1600MHz
OcUK 22x DVD±RW SATA ReWriter
I have the normal stuff like screen, keyboard and mouse. I also have an OS and I have a 320gb 2.5in hdd.
My budget is around £300 but the spec above only comes to £253 but that's without the graphics card and I will probably buy that later if I need it.
I don't really want an overkill pc because I don't wanna spend too much.
The phenom says it supports upto 1333MHz memory but the crucial is 1600MHz will this be ok?
What is the highest graphics card supported by the Corsair CX430?
Thanks.
Phenom II X4 955
Asus M5A78L-M/USB3
Thanks.
