First build
7 Aug 2012
I'm building my first gaming pc and would like some thoughts on the spec i chose.
MSI HD 7970 Lightning 3072MB GDDR5 PCI-Express Graphics Card - £349.99
AMD Bulldozer FX-8 Eight Core 8150 Black Edition 3.60Ghz - £139.99
ASRock Fatal1ty 990FX Professional AMD 990FX - £131.66
Corsair Vengeance RED 16GB (4x4GB) DDR3 PC3-17100C11 2133MHz Dual/Quad Channel Kit - £124.99
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - £76.66
Akasa Venom 750w Modular '80 Plus' Power Supply - £66.66
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler - £37.49
A couple of qustions, first would i be likely to encounter issues with the ram with regards to the CPU cooler or would i need lower proflie chips?
Second would the PSU have any problems with this? it will need to be upgraded eventually as in time id like to upgrade the RAM, add a BlueRay drive and get a second graphics card but they can wait for now.
Hello and welcome to the forum :)
I assume the main use of the pc is for gaming?
What is your budget?
Switch cpu too a i5 2500k or 3570k U would also need to change to mobo for that but im on my phone so cant make a list :( but if your using it for gaming and have a decent budget 1 tip everyone will tell you bin the Amd cpu there scrap compared to intel in gaming.
Thank you all fopr the advice. End build looks like this.
Sapphire HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card - £279.99
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - £149.99
Gigabyte Z77X-UD3H Intel Z77 (Socket 1155) DDR3 Motherboard - £108.32
Aerocool X-Predator Ultimate Gaming Case - White - £99.16
Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze' Power Supply - £79.16
Samsung 128GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - £74.99
Microsoft Windows 7 Home Premium SP1 64-Bit -£69.99
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - £69.16
Phanteks PH-TC14PE CPU Cooler - £55.82
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - £29.99 x2
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £14.99
Phanteks 140mm Fan PH-F140TS_WT £14.16 (for the empty back slot on the case)
(prices ex. VAT)
i wouldnt get "green" drives, most have the lag when you access em (cuz they need to spin up from their slow spinning state) and their max rpm is also slow (5400-5900 vs 7200 for a vanilla drive)
