First Build
19 Jul 2023
england
Hello guys,
I am building my first PC. It will be used for gaming. My budget is £2000. I don’t need any peripherals. I have an 4K monitor. Either AMD or Intel build. Can anyone spec me for this please?
Thanks in advance.
Would you say this is good or bad? Thought I would try building one myself
Many thanks for the help
Link shows nothing as parts
If you want to share a basket of parts then add everything you want then go to your basket , scroll down the basket page and there is a button BB code .
Press it and a box will pop up, copy everything in the box then paste it here and post.
You need DDR5 memory with that motherboard you have DDR4 in your list and your psu is a little weak I would put a 1000w unit in there which you can get for £10 less but gold rated.
DDR5.
Help needed please, I’ve put together my pc but I can’t get it to power up. I have CORSAIR HXi Series HX1000i FM with a b650 aorus elite ax motherboard. The top left of the motherboard has a 4 pin plug and a 8 pin plug my power supply come with the 8pin but no 4 pin. Is the 4pin what I’m missing?
You only need the 8 pin
Any lights or fans spinning ?
Check for error codes, usually top right of your motherboard will show if the issue is RAM, CPU, etc. also worth trying to disconnect anything but the necessary.
What is the spec you went for?
You should have 2 x EPS cables, the motherboard end should split into 2 x 4 pin plugs. (you should be fine with only the 8 pin connected)
As tamzzy said, a few pics may help.
Sorry guys I’m new to the pc world it’s all a bit mad I’m used to turning on my console. I’ve handed the build over to a mate who knows a bit more about pc.
My motherboard wasn’t showing any errors codes I don’t believe it has an error code panel.
Page 18 shows you motherboard has status led lights by the 24 pin power connector.
Hi guys I got the build all up and running! Really be enjoying my time playing a pc over console, can’t believe it’s taken me this long to make the change!
I have a Gigabyte 4080 16GB GAMING OC graphics card and I’m looking at getting the Lian Li strimer v2 cable could someone show me the right one please
Many thanks
Many thanks
If your psu is not atx 3.0 then the 3rd one is 3 x 8 pin?
