First burn tests
17 Oct 2012
Norf FC Yorkshire
I've just done my first cpu stress tests using the intel burn test but because i have nothing to compare it to i'm not sure weather the results are any good. I did a standard test 10times in 594.72 secs, temps were 28-55C, the gflops were about 20-21. The 2nd time i did a high test 10times in 1581.02, got the same temps, gflops were 21. This was 32bit os using 2gb of the 3.25gb that xp sees. Also the cpu is a fx6200 @3825mhz.
