First camera ~£100
A2Z
A2Z
9 May 2005
Earth
What would be a good camera to get someone who just wants to get started with photography for about £100?
Would a Nikon D40 2nd hand be a good choice? Or maybe a Canon EOS 6.3MP Rebel new would be better? Or Canon PowerShot SX400 new? Can all be had for ~£100
Thanks!
If they really want to get into photography for real then they need a camera with manual controls. With a point and shoot you can't learn much more than composition. So a second hand DSLR is probably the way to go.
£100 is tight but maybe you could pickup a Canaon 300D / 350D for around that price. Personally I would try and stretch to a 400D that takes SD card memory and has auto ISO.
You need to choose between a compact camera and a DSLR. The compact will be more portable, the DSLR will allow you to change lenses (you can expand your collection over time) and usually will have a better sensor. It does depend on the type of photography you want to do and how much gear you're willing to lump around.
Whether you choose a compact or a DSLR, if you want to learn about photography you need something which will allow you to switch to Manual, Aperture Priority, Shutter Priority modes etc. Whilst it's fine to leave things on automatic for day to day shots, to get the best out of your camera you need to learn how to control aperture, shutter speed etc.
£100 won't get you that far with a new camera. But you could probably pick up a good bargain second hand because a lot of photographers do like to upgrade fairly regularly. Remember that megapixels aren't everything, quality of sensor matters more. So even a 10 year old DSLR could be a good purchase if it has been well looked after.
Check the second hand market for a compact or DSLR that will allow you to switch to Manual, Aperture, Shutter etc. I picked a nifty Olympus xz2 for £100 as a spare from Cex or check the MM on here.
