First Console - which
26 Dec 2009
London
So i'm pretty much set on the 360, hate the ps3 controller and I had the original and found it a good console.
Theres a deal for the 360 and halo3 for £157 plus maybe £20 cash back.
In terms of deals how is this and is it worth it?
How big is the hard drive?
If its the 250GB version its a very good deal. If its the 4GB version, I think you can shop around to get a better deal. ie, console at £140 and a couple of pre owned games to £160?
Your right about the controller. The xbox left hand stick that is mounted higher is a much better design.
Yes 250 yes on HUKD - should i or shouldnt i - i know what you guys think, i'm hoping i get time for it, especially since i built a new gaming pc and just about get to play pc games. Ahhh decisions....
OT but just bought settlers 7 from pcworld, awesome game!
EDIT - Bit the bullet got from Asda with 250GB + Halo 3 and hopefully £20 with TCB - £157 (£137).
Thought i'd go for it, can just got back to store and return if it comes to that.
