First custom loop build - is this spec OK
20 Feb 2016
So im going to make a custom loop with the following items and I need to know if what i've got is right or not ;)
Components
CPU - i7-5930K 3.50GHz (Haswell-E) Socket LGA2011-V3
MOBO - Asus Rampage V Extreme USB 3.1 Intel X99 (Socket 2011)
RAM- 2x Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz
PSU - Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply
GPU - GeForce GTX 980 DirectCU II OC Strix 4096MB GDDR5 < already in current system
CASE - Obsidian 750D Airflow Full Tower Case - Black
Water Cooling Parts
Reservoir - EK-RES X3 250 + EK-RES X3 Multiport Top
Pump - EK-XTOP Revo D5 PWM
Rads - EK-CoolStream XE 240 (Double) + EK-CoolStream PE 360 (Triple)
Tubes - 3x EK-HD PETG Tube 10/12mm 500mm (2pcs)
EK-RES X3 - Internal Tube 12/16 140mm
Fittings - 8xEK- HDC Fitting 12mm G1/4 - Black
2xEK-AF Angled 2×45° G1/4 Black
Drain - 1x EK-AF Ball Valve (10mm) G1/4 - Black + EK-HD Adapter 10/12mm - Black
Coolant - Mayhems Ultra Pure H2O 5Ltr
Mayhems Biocide Extreme
Gpu Blocks - EK-FC980 GTX Strix - Nickel
EK-FC980 GTX Strix Backplate - Nickel
Cpu Block - EK-Supremacy EVO
I think I've covered what I need but as this is my first water cooled build i am not sure If what Is on the list in 100% correct. Any advice is welcome advice thanks. :D
Your gonna need some more commpresion fittings,you need 2 per component,so you will need 12 total.Your probily gonna want a few more 90 fittings aswell just to be safe,you already got a bending kit for the tubes?
Where you planning on putting the drain?you will probily need a t fittings aswell as a male to male extender for that too.For convenience i would get a pump/res combo instead of separate ones,buts either way it doesn't matter.Everything else is fine tho,assuming you already have fans :D
Will add those fittings to the list just to be safe :D Yes i have a bending kit for the tubes. i was gonna put the drain at the bottom right of the Reservoir. what pump/res combo would you recommend? and as for fans i have a load of NF-P12-PWM 120mm Silent Case Fan - PWM in my current system. But if you can recommend quieter push fans then ill look into it . thanks
