Hi Guys
Looking to do my 1st loop, primarily to combat the noise from my 3080 which locks itself to a min 30% fan speed soon as any usage is put through.
I am looking at getting the DarkBase 900 and using a 420 rad in the front.Just wanted to check if below would be okay, or if there are any better recommendations. Specs are below for GPU and CPU
CPU: Intel i7-8086K (delidded 5ghz)
GPU: Palit 3080 Gaming Pro
Any help would be greatly appreciated
My basket at Overclockers UK:
- 1 x Corsair Hydro X Series XD3 RGB Black Reservoir / Pump Combo (CX-9040003-WW)= £89.99
- 1 x EK Water Blocks EK-Tube ZMT Matte Black 16/11mm - 3m= £13.49
- 2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L= £6.95
- 1 x EK Water Blocks EK-CoolStream CE 420 (Triple Fan) Radiator= £92.99
- 1 x EK Water Blocks EK-AF T-Splitter 3F G14 - Nickel= £7.99
- 8 x EK Water Blocks EK-Quantum Torque STC 12/16 Soft Tube Compression Fitting - Satin Titanium= £7.99
- 1 x Corsair Hydro X Series XC7 RGB Black CPU Water Block - 1200 / AM4 (CX-9010006-WW)= £69.95
- 1 x EK Water Blocks EK-Quantum Vector RTX 3080/3090 D-RGB Graphics Card Water Block - Nickel + Acetal= £154.99
- 1 x be quiet! Dark Base 900 Full Tower Gaming Case - Black= £179.99
- 1 x EK Water Blocks EK-AF Ball Valve (10mm) G14 - Black Nickel= £12.95
- 1 x EK Water Blocks EK-ATX Bridging Plug (24 pin)= £1.99
- 2 x EK Water Blocks EK-Quantum Torque Rotary 90 Degree Fitting - Satin Titanium= £8.99
Total: £734.83 (includes shipping: £14.70)
£15
(incl. VAT)
£11
(incl. VAT)
. (I have a specially folded one that lives on my desk)
