- 21 Jun 2011
Hello folks,
current system has the CPU cooled by an all-in-one cooler (Antec 620 IIRC) but my GPU is still noisy.
I'd like to try water cooling the GPU.
I know I'll need a water block, likely a back plate, a pump, reservoir, radiator, fans and tubing (plus coolant) but I have decided to start by looking at the block.
I have an MSI HD7950 3Gb boost edition Twin Frozr 2 - I don't know if it's reference 7950 or 7970 PCB design - any way to tell without dismantling?
Any recommendations for a water block for such a card?
Once I get an idea how much the block will be, I will start working out the full budget, and whether it'll end up being a full loop or GPU only (I suspect GPU only).
