Hi peeps! This will be my first DIY build. I have had a good look round on this site and various others at all the brilliant info out there and I think I have finally decided on a set-up I think will work.
I have never spent this much in one go (~£1200) and am pretty much pushing my price limit so, I'm looking for, firstly, a thumbs up to say all this will work together
Asus MAXIMUS V GENE Z77
Intel Core i5 3570K 3.4GHz
Corsair Vengeance 8GB (2x4GB) DDR3 1600Mhz (black)
Corsair Vengeance 8GB (2x4GB) DDR3 1600Mhz (red)
Asus GTX 560Ti DirectCU II 1GB GDDR5 (x2)
OCZ 90GB Agility 3 SSD - 2.5" SATA-III
Seagate 1TB Barracuda 3.5" SATA-III Hard Drive
LGBH10LS38 10x BD-RW
Corsair AX850 Modular PSU
Microsoft Windows 7 Home Premium w/SP1
Secondly, are there any parts I should avoid or swap, bearing in mind I'm already at my budget so if there are better options that are the same price but cheaper then go ahead. Please don't take me the wrong way on this but I don't want to see "Well.. if you spend and extra £10 here and another £20 there..." that's how things get too expensive
And lastly are there any obvious parts missing aside from the case - I know that's missing; I still can't choose (atm I think arc mini but can't seem to find any...) so everything will be going in my old case for now.
So, how many of you went tl:dr ?
Thanks in advance peeps!
p.s once this is approved there will be some slightly more technical questions on set-up but we'll see how we go. For example I intend this to fit in a micro-atx case AND to be watercooled, but it will be aircooled to begin with so no over clocking tips yet, I dont want my core to melt
