First ever build, hopefully upgradable!
28 May 2020
Hi I'm hoping to build my first gaming pc. I want something I can upgrade on birthdays and Christmas. Any alternate suggestions would be great.
  1. MOBO. asrock-x570-phantom-gaming 4 AMD £152.39
  2. GPU. asus-radeon-rx-570-8gb-rog-strix-oc-gaming £144.98
  3. CPU. AMD-ryzen-3-3300x £119.99
  4. Case. msi-mag-forge-100m-black-mid-tower-w-tempered-glass-window-3x120mm-2xrgb-fans. £49.99
  5. Psu 550w-antec-ea550g-pro-80plus-gold-hybrid-modular-power-supply. £69.98
  6. RAM. 16gb-2x8gb-corsair-ddr4-vengeance-rgb-pro-white-pc4-25600-3200-non-ecc. £80.99
  7. Storage for os. 500gb-gigabyte-aorus-ssd-m2-2280-pcie-40-x4-nvme-ssd. £116.99
I will be also using a 2tb standard ssd. Approx cost £758.11, I don't want to go over that figure. But maybe next year change the course then maybe the gpu.
Any ideas/suggestions greatly appreciated.
  • MOBO. asrock-x570-phantom-gaming 4 AMD £152.39
  • GPU. asus-radeon-rx-570-8gb-rog-strix-oc-gaming
  • Storage for os. 500gb-gigabyte-aorus-ssd-m2-2280-pcie-40-x4-nvme-ssd. £116.99
Get a cheaper b550 board
Don't really need a nvme ssd for os just use your 2tb ssd for everything
And with the extra money, have enough to get a rx5600xt/5700
Scrap that near double GB price PCIe v4 NVMe.
Theoretical speed shows only in benchmarketing, while space you don't have shows after installing couple big games.
£75 is max price for small half TB drive in that budget.
https://www.overclockers.co.uk/wd-b...-solid-state-drive-wds500g2b0c-hd-56k-wd.html
Whole NVMe doesn't really make much difference over SATA SSD in existing games and Windows loading time difference is even smaller:
