- 5 Apr 2007
Hi folks.I'v been reading the forum for a few weeks now, and I like how helpful and friendly place it is. I'm looking for a new system,pretty much for games.
Arctic Silver 5 Thermal Compound (3.5g)
Antec Nine Hundred Ultimate Gaming Case
Enermax Infiniti 720W EIN720AWT ATX2.2 Modular SLI Compliant PSU
Samsung SM-206BW 20" Widescreen LCD Monitor - Silver/Black
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB)
BFG nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
CellShock 2GB (2 x 1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM 112DBK 18x18 DVD±RW Dual Layer ReWriter - (Black)
Tuniq Tower 120 CPU Cooler
How do you cut and paste good?????????????
oh well.
A few things,
-memory i'm not sure about manufacturers?Whats best for my needs. Is it worth getting 4gig also?
btw i'm going to try overclocking the cpu as doesnt sound too hard.
-Reguarding the monitor,is it better getting the 22" even though the resolution is the same as the 20"?20" inch sounds like the quality will be better?
-Windows vista? 32bit or 64bit??????? aint got a scooby which one.
that spec comes to 1512. thats the budget give or take a little.
I understand some things are personal preferances but any thoughts welcome
Cheers
oh well.A few things,
Cheers
