- 4 Jan 2013
- kent
hi guys,
my plan of action is to build my first ever pc
i've been an avid gamer since i can remember and i've never actually got round to building my own gaming pc, so it's time to do just that.
obviously this build will not be replacing my current pc as it's merely for practice and if all goes well and i don't blow myself up then it'll just be used by other members of the family so they no longer have to use MY machine.
i know it's fairly straight forward building a pc, i've watched many tutorials and read up on it a fair bit. the only thing i'll probably suck at is cable management.
i'm not sure what my budget for this build is but i'd like it to be as cheap as possible, but, here's the twist! and now i'll probably get laughed at.
once i've built this machine i'd then like to attempt (very important word there)
to watercool it
only basic stuff, none of the top of the range watercooling equipment. just cheap and cheerful.
so with this in mind, what would you guys recommend?
i wont be buying the watercooling gear straight away, i'll be building the machine first and then when i have the funds watercooling it.
ideally i'd like an intel set up. so what cpu/mb is fairly cheap and will be compatible with watercooling? same goes for the psu and maybe the gpu(was only looking to watercool the cpu but if it isn't too much to do it with a gpu then i'll do it)
i'm not fussed about mounting the rad out side of the case either, cosmetics mean nothing here (plus i know decent watercooling cases cost a fortune)
this is purely for me to learn something new and have a bit of fun.
sorry for the wall of text and any help will be appreciated
to watercool it
