First ever overclock , advice please.
GPR
GPR
16 May 2012
Hi, Could i ask for some advice please.
My Spec is,
Intel core i7 930 2.8G s1366
ASUS Rampage 11 extreme X58
6GB 3x2 CMP6GX3M3A1600C8 DHX
1536MB EVGA GTX480 PCI-E
750 CM Extreme GX 80+ PSU
T/R Ultra - 120 extreme 1366
150G WD WD1500HLFS Veloctrap
2x500GB Hard Drives
I have overclocked for the first time and going by the info could anyone advise if all looks ok .
This pic just after pc restart.
This pic running Prime96
This is the results from Prime95
[Mon May 21 13:05:46 2012]
Compare your results to other computers at http://www.mersenne.org/report_benchmarks
Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
CPU speed: 4000.51 MHz, 8 cores
CPU features: RDTSC, CMOV, Prefetch, MMX, SSE, SSE2, SSE4
L1 cache size: 32 KB
L2 cache size: 256 KB, L3 cache size: 8 MB
L1 cache line size: 64 bytes
L2 cache line size: 64 bytes
TLBS: 64
Prime95 64-bit version 25.11, RdtscTiming=1
Best time for 768K FFT length: 8.786 ms.
Best time for 896K FFT length: 10.668 ms.
Best time for 1024K FFT length: 12.010 ms.
Best time for 1280K FFT length: 15.146 ms.
Best time for 1536K FFT length: 18.320 ms.
Best time for 1792K FFT length: 22.105 ms.
Best time for 2048K FFT length: 24.984 ms.
Best time for 2560K FFT length: 33.311 ms.
Best time for 3072K FFT length: 40.595 ms.
Best time for 3584K FFT length: 49.353 ms.
Best time for 4096K FFT length: 55.688 ms.
Best time for 5120K FFT length: 71.424 ms.
Best time for 6144K FFT length: 85.086 ms.
Best time for 7168K FFT length: 103.255 ms.
Best time for 8192K FFT length: 116.866 ms.
Timing FFTs using 2 threads.
Best time for 768K FFT length: 9.031 ms.
Best time for 896K FFT length: 10.988 ms.
Best time for 1024K FFT length: 12.461 ms.
Best time for 1280K FFT length: 15.808 ms.
Best time for 1536K FFT length: 18.841 ms.
Best time for 1792K FFT length: 23.047 ms.
Best time for 2048K FFT length: 25.540 ms.
Best time for 2560K FFT length: 34.043 ms.
Best time for 3072K FFT length: 40.542 ms.
Best time for 3584K FFT length: 49.766 ms.
Best time for 4096K FFT length: 54.880 ms.
Best time for 5120K FFT length: 70.912 ms.
Best time for 6144K FFT length: 84.593 ms.
Best time for 7168K FFT length: 102.793 ms.
Best time for 8192K FFT length: 113.520 ms.
Timing FFTs using 3 threads.
Best time for 768K FFT length: 5.388 ms.
Best time for 896K FFT length: 6.414 ms.
Best time for 1024K FFT length: 7.844 ms.
Best time for 1280K FFT length: 9.160 ms.
Best time for 1536K FFT length: 10.942 ms.
Best time for 1792K FFT length: 13.436 ms.
Best time for 2048K FFT length: 14.798 ms.
Best time for 2560K FFT length: 19.929 ms.
Best time for 3072K FFT length: 23.897 ms.
Best time for 3584K FFT length: 29.316 ms.
Best time for 4096K FFT length: 32.381 ms.
Best time for 5120K FFT length: 42.216 ms.
Best time for 6144K FFT length: 50.472 ms.
Best time for 7168K FFT length: 61.424 ms.
Best time for 8192K FFT length: 68.058 ms.
Timing FFTs using 4 threads.
Best time for 768K FFT length: 5.247 ms.
Best time for 896K FFT length: 6.054 ms.
Best time for 1024K FFT length: 7.576 ms.
Best time for 1280K FFT length: 8.257 ms.
Best time for 1536K FFT length: 9.930 ms.
Best time for 1792K FFT length: 11.923 ms.
Best time for 2048K FFT length: 13.364 ms.
Best time for 2560K FFT length: 17.543 ms.
Best time for 3072K FFT length: 20.906 ms.
Best time for 3584K FFT length: 25.426 ms.
Best time for 4096K FFT length: 28.232 ms.
Best time for 5120K FFT length: 36.683 ms.
Best time for 6144K FFT length: 44.130 ms.
Best time for 7168K FFT length: 53.025 ms.
Best time for 8192K FFT length: 59.354 ms.
Timing FFTs using 5 threads.
Best time for 768K FFT length: 4.260 ms.
Best time for 896K FFT length: 4.888 ms.
Best time for 1024K FFT length: 6.310 ms.
Best time for 1280K FFT length: 6.368 ms.
Best time for 1536K FFT length: 7.611 ms.
Best time for 1792K FFT length: 8.860 ms.
Best time for 2048K FFT length: 9.979 ms.
Best time for 2560K FFT length: 13.003 ms.
Best time for 3072K FFT length: 15.707 ms.
Best time for 3584K FFT length: 19.139 ms.
Best time for 4096K FFT length: 21.449 ms.
Best time for 5120K FFT length: 27.967 ms.
Best time for 6144K FFT length: 34.955 ms.
Best time for 7168K FFT length: 42.290 ms.
Best time for 8192K FFT length: 47.332 ms.
Timing FFTs using 6 threads.
Best time for 768K FFT length: 4.429 ms.
Best time for 896K FFT length: 5.088 ms.
Best time for 1024K FFT length: 6.534 ms.
Best time for 1280K FFT length: 6.682 ms.
Best time for 1536K FFT length: 8.051 ms.
Best time for 1792K FFT length: 9.225 ms.
Best time for 2048K FFT length: 10.481 ms.
Best time for 2560K FFT length: 13.031 ms.
Best time for 3072K FFT length: 15.630 ms.
Best time for 3584K FFT length: 18.241 ms.
Best time for 4096K FFT length: 20.624 ms.
Best time for 5120K FFT length: 26.236 ms.
Best time for 6144K FFT length: 33.971 ms.
Best time for 7168K FFT length: 41.026 ms.
Best time for 8192K FFT length: 46.641 ms.
Timing FFTs using 7 threads.
Best time for 768K FFT length: 3.921 ms.
Best time for 896K FFT length: 4.495 ms.
Best time for 1024K FFT length: 5.813 ms.
Best time for 1280K FFT length: 5.878 ms.
Best time for 1536K FFT length: 7.065 ms.
Best time for 1792K FFT length: 8.119 ms.
Best time for 2048K FFT length: 9.150 ms.
Best time for 2560K FFT length: 11.441 ms.
Best time for 3072K FFT length: 13.640 ms.
Best time for 3584K FFT length: 15.921 ms.
Best time for 4096K FFT length: 18.185 ms.
Best time for 5120K FFT length: 23.073 ms.
Best time for 6144K FFT length: 30.383 ms.
Best time for 7168K FFT length: 37.050 ms.
Best time for 8192K FFT length: 42.566 ms.
Timing FFTs using 8 threads.
Best time for 768K FFT length: 4.076 ms.
Best time for 896K FFT length: 4.707 ms.
Best time for 1024K FFT length: 6.035 ms.
Best time for 1280K FFT length: 6.204 ms.
Best time for 1536K FFT length: 7.491 ms.
Best time for 1792K FFT length: 8.572 ms.
Best time for 2048K FFT length: 9.785 ms.
Best time for 2560K FFT length: 12.159 ms.
Best time for 3072K FFT length: 14.582 ms.
Best time for 3584K FFT length: 17.124 ms.
Best time for 4096K FFT length: 19.365 ms.
Best time for 5120K FFT length: 24.273 ms.
Best time for 6144K FFT length: 31.728 ms.
Best time for 7168K FFT length: 38.608 ms.
Best time for 8192K FFT length: 44.562 ms.
Best time for 58 bit trial factors: 1.848 ms.
Best time for 59 bit trial factors: 1.867 ms.
Best time for 60 bit trial factors: 1.866 ms.
Best time for 61 bit trial factors: 2.061 ms.
Best time for 62 bit trial factors: 2.180 ms.
Best time for 63 bit trial factors: 2.575 ms.
Best time for 64 bit trial factors: 3.148 ms.
Best time for 65 bit trial factors: 3.347 ms.
Best time for 66 bit trial factors: 3.517 ms.
Best time for 67 bit trial factors: 3.487 ms.
Could anyone suggest anyother software to check my overclock.
Thanks
Gary
Thank you for your advice, I have the voltage set to AUTO, where would I find the correct voltage to add , would I find this when running CPU-Z on idele.
Thanks again
Gary.
Try 1.3v and drop speed down to 4ghz
In your second screenshot change cpu voltage from auto
I don't know much about overclocking that cpu but 1.43v is way too high
same here about the cpu.
always take the voltage of auto and manually set the voltage yourself in the bios.
when you change it to manual, it will then display the voltage, just raise it (pic 2)
also you dont need to post all the prime results, just do a screen grab after a couple of hours
