First ever PC build, boots up but no display to monitor
15 Apr 2020
Hello, my build is Ryzen 3600, xfx 5700 XT, 16gb (2x8gb) 3600 DDR4 Ram, B450m-plus gaming motherboard. Everything is powering up fine but there's no display at all to the monitor, I tried resetting the CMOS by removing the motherboard battery which had no affect so I'm completely unsure what to try next. Any help is greatly appreciated, thank you in advance
As silly as it sounds but have you checked the monitor is displaying the correct output?(i.e if you have displayport connected and make sure the monitor is enabled to that port for signal)
Did the box your motherboard came in have a ryzen 3000 ready sticker as if it didn't then there's a good chance it will need a bios update for compatibility.
Have you checked all of your cables are plugged in properly, both the 24-pin motherboard cable and the 8-pin CPU power at the top of the mobo?
