Hi all,
This is my first post here, I joined recently because I want to build a PC and wanted some advice.
I am going to be using the PC for day-to-day use, watching movies, programming, a bit of gaming and maybe a bit of photo editing. So I am not going for an extreme gaming PC, I just want a fast/better than average PC, that can be used for all of the above, and that I can say I have built myself.
I do not want to spend too much, my budget for the PC is around £750 incl VAT, I'd prefer it it was closer to the £700 mark, and obviously cheaper than that is even better
Below is what I'm thinking of:
- Intel i5 2500k 3.3GHz Sandybridge 1155
- MSI P67A-G45 Intel P67 (1155)
- Kingston HyperX Blu 8GB
- MSI GeForce GT 430 OC Twin FrozR 1024MB
- WD Caviar Black, 1TB
- OCZ Agility 60GB SSD
- Samsung BluRay Drive
- Samsung DVD RW
- Akasa Venom CPU Cooler
- DeepCool Ultra Silent 80mm Fan X2
- Gelid Silent 120mm Fan
- OcUK Case
- OCZ ModXStream 600w Silent Modular PSU
Total: £727.85 incl VAT
What do you think?
I know that some say 4GB RAM is enough, but like others say at the moment for the price you might as well go for 8GB.
So other than the RAM, is any extra money being spent anywhere it shouldn't be? And am I missing anything?
A few questions:
Firstly, is everything I have specced compatible? Enough slots on motherboard for everything etc?
How do I know what wattage PSU I need? And is the one I specced 'fully' modular or not? Because the one that I specced above I just randomly added to give me a rough guide on price as I was not sure on the wattage, so that may not necessarily have all the necessary connections.
Are there any reasonable priced graphics cards that have two HDMI outputs? So I can have one for my monitor and one for my TV if I'm watching a movie. Or is there a better way of doing this?
Are all the cables that I would need for this build included with this or do they need to be purchased separately ?
I 'might' overclock it, but I definitely do not want to damage anything. When it says "Automatically overclock CPU and Memory in 1 second", how does this work and more importantly is it totally safe to do? Is it like a button/switch that motherboards have that allow you to instantly overclock them? I heard about that from this video, mentioned at 4m20sec into the video:
What is the difference between P67, H67, H61 Chipset and for my processor which do I need, or are they all compatible?
Does the blu-ray drive burn/read normal CD's/DVD's?
What is the main difference between the WD Caviar Green, and Caviar Black? The overclockers website does not say the spin speed of the green one?
Similar to the PSU, I wasn't at all sure on the case, and it was just added to give a guide on price, so I didn't check if it has enough space for the things I am looking at (apart from fans, which is the reason I specced those fans). So is there a better case for a reasonable price, preferably with a window and USB ports on it? I'm not sure which cases are good.
Are fan controllers worth the money?
Is the SSD worth the money for the faster boot times? I think it is, but what do you all say? And is it an issue with having an SSD for the OS, and another drive for your files etc? What I mean by that is do programs install ok onto the drive that does not have the OS on and does the PC try to install things onto the SSD as default because that is where the OS is, then you have to keep changing the install location every time you install anything?
That's all the questions I can think of for now, but I'm sure I'll probably have more soon.
Also I am going to London International Technology Show on Saturday where they are supposed to have discounted prices, so I'm hoping to buy certain things from there that I know will be compatible with whatever I buy from Overclockers, like Blu-Ray drive, HDD/SSD etc and try and save some money.
So what do you think?
Look forward to your replies and thanks in advance,
Azibux1
EDIT: Is a watercooling system for the CPU worth the money in this sort of build or not? And if so, which (reasonably priced one) do you recommend?
Also, I know it would be stretching the budget but if it is worth it, then it may be possible. Would it be worth the money to minus the CPU, motherboard, CPU cooler and RAM from my build and swap it with either of the following (probably the cheaper option of the two) as it would be much safer than overclocking it myself:
Krypton Z68 Intel i5 2500k 3.3GHz overclocked to 4.6GHz bundle
Krypton Z68 Intel i5 2500k 3.3GHz overclocked to 4.4GHz bundle
- Samsung DVD RW
- OcUK Case
What do you think?
A few questions:
Azibux1
