- 12 Jun 2014
- Manchester
First full custom loop|Project MonoChrome
This build started as just simply an upgrade... but soon got out of hand and has become a brand new build. The goal was to upgrade my current pc with a water cooled cpu... but then I expanded it to GFX cards and then later decided that It was too risky to try it on my current work pc since this is my first water loop.
Anyways new build!
Spec:
Asus Rampage IV Black Edition - (Cooled by XSPC Rampage 4 Black Waterblock Set)
Intel i7-4930K - (Cooled by XSPC RayStorm Block)
2x Asus R9 290 DCII (Cooled by EK-FC R9-290(X) DCII - Acetal+Nickel)
16gb Ram - Avexir Blitz 1.1 Original 2x2x4gb 2400MHz Dual Channel Memory Kit
XSPC H2 Case (will be doing a review of this case, but I think it is a discontinued line)
Colour Scheme: BLACK & WHITE
Black case, Black Rads, Black Mobo, Black blocks.
Highlighted with white lighting, PSU and fan cables and Tubing.
I use my pc for both work and gaming, so I hope to build a quite system that I can overclock to a fast but stable amount. I already overclock my current air cooled build, but it is not quite.
(edit 19/06/2014: added loop diagrams)
I have two loop layouts I am thinking of using:
Loop 1
Loop 2 (Chosen layout)
Not all the parts I need have arrived yet (mainly blocks and cooling parts) but I had enough to start fitting parts to the mobo:
Opened all the boxes with child like glee (I LOVE building pc's) heres the mobo sat on an anti-static mat:
Removed the blocks:
Using my Actriclean to prep everything for new TIM:
Applying some to the chipset:
Mostly clean, just needs residue removed:
Using MX-4 as my choice of TIM:
Applied the paste to the chipset and then used a piece of plastic to spread it thin:
Fitted the block:
Going to leave it here for now and post more later.
I would appreciate suggestions later in the build and hope you all enjoy watching this build grow.
(Edit:16/06/2014 Using thumbnail images)
Anyways new build!
Spec:
Loop 1
Removed the blocks:
Fitted the block:
