- 24 May 2011
Yes, but almost everything I want is out of stock lol. I'm guessing OCuk will get it for you once ordered?
Kind of. I haven't been able to fathom out where its bad supply or high demand that keeps most of the watercooling parts out of stock. They've normally always got the items on order just waiting on shipping though.
So I was thinking these components?
https://www.overclockers.co.uk/showproduct.php?prodid=WC-154-PM&groupid=962&catid=2776&subcat=2779
https://www.overclockers.co.uk/showproduct.php?prodid=WC-145-PM&groupid=962&catid=2800
https://www.overclockers.co.uk/showproduct.php?prodid=WC-274-PM&groupid=962&catid=2133&subcat=2135
https://www.overclockers.co.uk/showproduct.php?prodid=WC-533-EK
https://www.overclockers.co.uk/showproduct.php?prodid=WC-519-BP
https://www.overclockers.co.uk/showproduct.php?prodid=WC-145-PM&groupid=962&catid=2776
2x https://www.overclockers.co.uk/showproduct.php?prodid=WC-259-XS&groupid=962&catid=1523&subcat=1526
Anything I'm missing?
Try using the browser add-on for looking at baskets, as it makes it easier for forum readers to spot if you're missing something.
http://forums.overclockers.co.uk/showthread.php?t=18371076
YOUR BASKET
1 x XSPC AX360 Triple Fan Radiator - White £89.99
1 x PrimoChill 360mm AGB CTR System Phase II - Frosted £62.99
1 x Monsoon Hardline Pro Bender Kit 1/2 x 5/8 (16mm) - Value Bundle £59.99
1 x EK Water Blocks EK-D5 PWM Pump £58.49
1 x EK Water Blocks EK-Supremacy EVO White Edition £56.99
1 x Bitspower D5 MOD TOP S-Model G1/4 - White £49.99
1 x PrimoChill Revolver Compression Fitting Acrylic Tube 13/10mm Diamond 10-Pack - white £49.99
1 x PrimoChill Rigid Bender Bending Template - Clear £41.99
2 x PrimoChill 13/10mm Acrylic Tube 60cm 4-Pack - White £15.95 (£31.90)
Total : £502.31 (includes shipping : Ex.VAT).
Thanks so much for this! I was always wondering how people were doing this! I've updated aboveAny suggestions for more equipment from anybody?
You're welcome!
As for more equipment,regarding fluid, you might need a kill coil/biocide if you go for plain distilled water. Also, fans for the rad, fan controller, connectors for a drain point....
Can you recommend a good controller and connector for a drain point?
The 2 issues I see are that the backplates are for the Strix GPU and may not fit the stock board.
Also the Cable Mod kit is for a beQuiet DarkPower PSU not an EVGA one.
Also from a purely personal point of view I'd want the USB / Aquabus D5 pump from Aquacomputer, although I'm not sure that the Bitspower upgrade kit works with it.
I can't link it better than this due to forum rules (I can't find it on the OCUK site).
D5 Pump (You might have to translate it)
I has a water temp sensor, usb connection and will connect to the aquabus interface of the aquaero allowing more accurate control options.
2 x XSPC AX480 Quad Fan Radiator - White
1 x EVGA Pro SLI Bridge V2 - Long 2-Way
1 x Bitspower BP-CLTAC-S2 Crystal Link Tube Set For 2-Slots
1 x Bitspower BP-CLTAC-S3 Crystal Link Tube Set For 3-Slots
1 x IC Diamond 24-Carat Thermal Compound (4.8g)
1 x Akasa TIM Kit Thermal Compound + Cleaner & Spreader
2 x Bitspower Rotary Fitting "Q" - 360 Degree Water Cooling Accessory - Black Matte Finish
10 x Bitspower Premium G1/4" Matte Black High Flow 3/8" (1/2" OD) Compression Fitting
Are you certain on this?
The AX480 is very much overpriced and if you're not keen on the color you, EK PE480 is essentially the same rad in black.
Please note you cannot control the pump via (most) fan controller e.g. Aquaero.
But you can control via mobo PWM headers.
The EVGA bridge is for 60mm spacing = 3 slots
Not sure why you would need the crystal link tube set for 2 sets then..
Gelid GC Extreme or the Thermal Grizzle instead?
Second set...?
99% IPA would be more versatile... IMO
You might need some stop fittings to block the unused ports.
These are for soft tubing... not hard tubes
