First gaming monitor help
15 Nov 2020
Hello, I finally decided to get myself a proper monitor, my budget is not high and I have found two that match my needs and money wise but I cannot really decide which would be better. My GPU: asus radeon 5700xt
Im thinking between:
1. Aoc cq31g1 - 32inch curved qhd
2. Iiyama g-master gb 3266qsu-b1
Could someone help me which one would be better?
Both are VA panels, meaning dark shade involving transitions have slow response times known as "black smear".
This is what kind difference to modenr IPS is:
Though if you prefer darkened/dimly lit room, VA's the way best contrast of LCDs give best looking image.
IPS choise is very limited in 32" size, but 27" has lots of choises with prices going below £300.
Well most of the monitors that I came across on Amazon are with VA panels. I dont have very bright room, I would even say that it is darker than brighter. Another thing that is holding me back a little bit with a choice is that I want to take it on amazon instalments so my choices are limited. Those two are, at least in my opinion the best options out there at the moment but I cannot decide which one
